- This topic has 3 replies, 2 voices, and was last updated 6 years, 8 months ago by .
Viewing 4 posts - 1 through 4 (of 4 total)
Home › Forums › All Things 750 Twin › Technical Garage › 1982 Z750 CSR Rear Sprocket
I have a 16/38 sprocket setup on my bike. Does anyone have a make/model of a sprocket that would be smaller for the rear of larger for the front on my bike.
16/38 is the standard setup. In order to increase crusing speed you are right to increase the front sprocket size or reduce the rear sprocket size. The maximum you can fit on the front is 17 tooth. I have this with a 38 tooth rear and can cruise happily around 70mph. I am looking to improve on this by reducing the rear sprocket to 35 or even 33 tooth.
The problem I am having is to find a rear sprocket vendor that can supply a smaller than 38 tooth while staying with the 530 chain. Any experience with that?
They are out there. I would suggest contacting a seller and asking them.
