- This topic has 4 replies, 3 voices, and was last updated 15 years, 6 months ago by .
Home › Forums › All Things 750 Twin › Technical Garage › How To Fix It › alternator
electricketry not my strong point but should be the same 😀
I’m not sure the rotor is magnetised, as there is a coil in the centre of the alternator which is fed power from the regulator. As the voltage increases at the output the amount of current in the centre coil decreases and lowers the output to keep it at the correct voltage.
I believe the rotor just breaks the magnetic field to induce the current flow in the main windings. It is not a permanent magnet as far as I can tell.
Of course any and all information in this post could be totally wrong as it’s based on my own guesswork.
Thanks Phil
Hi All.
As a newcomer to the z 750 twin and am slowly finding my way around a rebuild. Regarding alternator, should the rotor be magnetised as others I have dealt with?
Hi Dougy
Thanks for that info. I have a spare bottom end which I have looked at. This rotor is not magnetic either so I think you are correct.
Graham
