Coil and rectifier issues
Home Forums All Things 750 Twin Technical Garage Coil and rectifier issues
  • #27639
    Rob
    In the midst of wiring bike and came across no charging voltage on battery – on inspecrtion of stator found some rather bad damage to it, looking to find a second hand one???? Also the 3 phase stator does it matter what order the wires go into he rectifier? ( 3 Yellows) Any help gratefully received- have the wiring diagram but doesn’t help when all the wires are yellow and the plugs been cut off!
    Cheers Rob
    On a plus side i did slap the tank on and got her running -Mint!!
    • This topic was modified 4 years, 9 months ago by Rob.
    #27641
    Kaptainkwak
    Well firstly congratulations on getting her running.
    It does NOT matter which order the yellow wires are in. It is a 3 phase charging circuit and each of the 3 phases are identical.
    I can help with the stator. I will send you a PM.
