- This topic has 3 replies, 2 voices, and was last updated 7 years ago by .
Home › Forums › All Things 750 Twin › Technical Garage › How To Fix It › CSR brake caliper help
Hi All
While doing the brakes on my CSR the bleed nipple snapped, after trying several methods to remove it I ended up drilling it out just when I thought I might have got away with it the drill was through the nipple and into the caliper.
So I now need a replacement caliper for a CSR going by partzilla this caliper was only fitted to the CSR does anyone know if there is a caliper from another model that will fit or does anyone have a spare CSR caliper.
Thanks for any help
Peter
Hi there
CSR brake calipers are still quite easy to find. I can probably dig one out if you need one, just let me know.
Hi KK
Thanks if you have a spare that would be great. I did have a look around on ebay and there were a few but all in the US, probably not the best time to be looking for spares either.
Peter
I have a spare caliper body. Will send a PM with details.
