Home › Forums › All Things 750 Twin › Projects and Progress › New Projects › my chop
- This topic has 29 replies, 6 voices, and was last updated 11 years, 8 months ago by
murf.
25th June 2013 at 8:30 pm #5324
murf
Participanthere she is dry build
25th June 2013 at 8:46 pm #9256samuria
Participantlooks a good base to put your own touch to…..
25th June 2013 at 10:46 pm #9245
KaptainkwakKeymasterI’m liking the look of that.
Great starting point as frame and forks are done. Will be nice to see progress
27th June 2013 at 5:38 pm #9262murf
Participantbad news on the engine only turns half way then locks up
27th June 2013 at 6:37 pm #9246
KaptainkwakKeymastermmmm
How have you tried turning the engine over?
27th June 2013 at 8:13 pm #9263murf
Participantkick start went about half way then locked up im going to take the cams out and see if it will turn over cant check the cam timing as theres nowt behind the points cover only the end of the crank took spark plugs out
27th June 2013 at 10:04 pm #9247
KaptainkwakKeymasterOK. It’s possible the engine has been opened and not put back together properly. Was the engine in bits when you got it?
Also do you have a manual?
28th June 2013 at 8:13 am #9264murf
Participantengine is the one in the pics no manual yet thanks murf
28th June 2013 at 11:55 am #9255dougyt
ParticipantLooks great Murf, hope you get that engine sorted out.
28th June 2013 at 5:49 pm #9265murf
Participantthanks guys took the cams out and the engine turns over sweet still got to take the head off to check the valves may be bent and ill pull the barrels of and check them may as well murf
28th June 2013 at 7:37 pm #9258
MichaelParticipantHi there,
even without the ignition parts on the crankshaft you can turn the pistons to top dead center.
The sprockets of the camshafts have an arrow (line) that must be horizontal aligned (parallel to the sealing surface).
Always remind that the crankshaft turns “backwards”, means counterclockwise when looking on the ignition side.
Cheers, Michael#1 and #4 in the drawing points to the arrow marks
28th June 2013 at 7:51 pm #9259
MichaelParticipantalways remember:
When tensioning the cam chain the cylinder head cover must be installed / in place !!!
Otherwise the cam chain may break and that will ruin the complete motor.
Cheers, Michael28th June 2013 at 9:36 pm #9248
KaptainkwakKeymasterExcellent reply Michael. I do not have the images like that but very educational.
29th June 2013 at 8:09 am #9266murf
Participantthanks michael nice one how doe you reset the cam chain aduster took mine out now dont now how far to put it back in if that makes sence murf
29th June 2013 at 8:29 am #9249
KaptainkwakKeymasterThe cam chain adjuster is fully manual to set.
1. Ensure the cams are correctly timed and the rocker cover is in place.
2. Assemble the plunger and spring inside the housing and screw in with your fingers until it becomes tight. Do NOT fit the locknut at this stage.
3. Check the end of the plunger shaft to see where it is in relation to the housing. If it is inwards then the housing needs to be screwed in further until the end of the shaft is flush with the housing face. If the plunger protrudes then the housing needs to be screwed out.
4. Rotate the engine by hand several times and watch the plunger move slightly in and out. Stop rotating when the plunger is at its farthest out position and screw the housing so its face is flush with the end of the plunger shaft.
5. Screw the locknut on and nip it up in place to prevent the housing from moving.
6. Rotate the engine by hand again to make sure the plunger does not protrude and adjust if necessary.
7. Re fit the cover ensuring the ‘O’ ring seal is in good order to prevent oil leakage.
