Home › Forums › All Things 750 Twin › Your Lonesome and you › MY KZ 750 TWIN
- This topic has 14 replies, 4 voices, and was last updated 13 years, 7 months ago by
Anonymous.
13th June 2012 at 9:00 am #8460
philpassinghamParticipantlike the look of that sir,chops should have a twin motor 🙂
13th June 2012 at 11:18 am #8466samuria
Participantthanks for the comment :pint:
14th June 2012 at 9:12 am #8461
KaptainkwakKeymasterI like the look of that. Well done sir.
Is the front end standard?
18th June 2012 at 8:01 am #8467samuria
Participantthanks for that,
the front end is standard.
having problems with the running though 😕 😕18th June 2012 at 10:10 am #8462
KaptainkwakKeymasterWhat kind of running problems?
Can you confirm what the original model is too. Looks like a CSR to me
18th June 2012 at 8:50 pm #8468samuria
Participanti think its a g1, its a import from usa. thats why its on a v plate. it was running on tickover. son as i touched the throttle it would die unless it had a bit of choke. went to give the cardbs a good clean today, all going well untill i tried to take off the drain plug and the bowl broke.
the last owner had used araldite to stick it on. so iam in the #OOPS#. needing a bowl. i was hoping to try and get them re-jetted as i have pods and a 2-1 pipe. any ideas wrer i could get the bowl and jets from please19th June 2012 at 12:11 pm #8463
KaptainkwakKeymasterTaking a closer look i think you could well be right with G.
Im quite sure ive a spare bowl possibly even a pair. I will look for jets too.
If you want any carb or fuel line parts http://www.nrp-carbs.co.uk/ are the place i always use. They have the bits, are reasonably priced and do a superb postal service.
I will send you a pm for your address
19th June 2012 at 3:42 pm #8469samuria
Participantthats very good of you, should there be any jets in the float bowls? there are none in mine!!! the bowl that broke had a overflow pipe on it, and can they fit on either carb? thanks for your help :pint:
20th June 2012 at 12:23 pm #8464
KaptainkwakKeymasterhave a look at this G1 Parts List
20th June 2012 at 10:05 pm #8470samuria
Participanti cant!!!! every time i click the link
i get a page that says session timed out!!!!!!21st June 2012 at 11:05 am #8465
KaptainkwakKeymasterTry this one. Click on ‘parts diagrams’ in the right hand list. You may need to allow pop ups
21st June 2012 at 1:19 pm #8471samuria
Participantthanks kaptainkwak.
i will give you a call to-night
regards les26th July 2012 at 11:19 pm #8473Anonymous
Inactivehi i am new to this site, but i have a set of bs34’s i can part with the bowl if you cover the shipping… i have an abundance of stock parts for these twins… i kind of became obsessed with them… next month i am having my head ported polished and milled .025.. then swapping cams out.. should bring this motor to life
27th July 2012 at 9:41 pm #5171samuria
Participant27th July 2012 at 9:41 pm #8472samuria
Participantmany thanks for the offer…
i have now fitted gpz 500 carbs.
a lot lighter. and a more modern carb.
