- This topic has 5 replies, 3 voices, and was last updated 17 years, 12 months ago by .
Home › Forums › General › Everything Else › mystery front wheel ?
Nice table cloth
any ideas ???
T19x2.15TL DOT – LESTER 9.13.78
Thats an after market american mag wheel, Lester sold loads in the 70’s to spokey wheel folk who wanted to keep up with the times.
Far better kit than early kwak mag wheels as they were made from aircraft grade alloy that didn’t go furry the first time you took a wet rag to it.
why thank you sir !
no need to preach to the converted then !
still trying tofigure out what it’s from …
maybe the internal threads are for an o’seal insert ?
maybe xs650 cb750 or even gt750 …
doubtful if it’s kawasaki ??
I assumed it came off a twin given where we are, chances are its off a cb honda of some sort or an early goldwing if its got threaded bearing retainers.
early four pot hondas had alloy hubs with alloy threaded collars that had seized solid by the time you needed to change the bearings, sensible folk used loctite and chucked the collars away which looks to be the csae in this instance.
Funny you should ask, there is a discussion on KZr about that very same bedspread:)
http://kzrider.com/component/option,com_joomlaboard/Itemid,33/func,view/catid,9/id,198587/#198612
