Home › Forums › All Things 750 Twin › Technical Garage › How To Fix It › need a new coil?????
- This topic has 19 replies, 5 voices, and was last updated 17 years, 11 months ago by
norman.
1st March 2008 at 7:05 pm #6808
norman
ParticipantOn my KZ750 am only getting spark on plug when touched to engine about 7 out of ten.
Points OK
Plugs and HT leads ok
Any suggestions Please
1st March 2008 at 7:07 pm #6809norman
ParticipantThe coil on it appears to be an aftermarket unit it is japanese in origin
If i need a new one any good sources please.
1st March 2008 at 7:35 pm #6810norman
ParticipantHi
have both plugs out of engine attached to ht leads and touchinh engine
one plugs sparks every time and the other 7 out of 10 this is with freshly charged battery on electric start
1st March 2008 at 7:57 pm #6799
KaptainkwakKeymasterright thats a clearer picture.
Firstly if one plug is sparking 10 out of 10 then the coil itself is fine as its the same one for both plugs so that can only be the Lead, Plug Cap or Plug itself.
Have you tried swapping the plugs round to see if the problem switches sides? that would confirm/eliminate the plugs.
Next try the same with the Plug caps and finally, as you think its an aftermarket coil, will the HT leads unscrew at the coil end? If they do and neither of the above 2 ideas give results i would fit new HT leads.
Let us know
1st March 2008 at 8:35 pm #6804BiqueToast
Participantnorman wrote:..one plugs sparks every time and the other 7 out of 10 this is with freshly charged battery on electric startI’m one of those people that believes in replacing the coil without hesitation. You’re going to need them sooner or later anyway…
Both the stock coils on my 750s were crap – and I didn’t know this until I got new ones and got to see the difference! They were misfiring just like you describe. When under heavy acceleration, I always felt this sort-of… hesitation… stammering…
Anyway, I got a 5 Ohm Dyna (for bike with points) and wires from z1enterprises.com… with the current exchange rate, that should be pretty affordable for you chaps, I’d imagine.
1st March 2008 at 10:19 pm #6811norman
ParticipantThanks kaptain and Bique
I’ll try a combination of both
Regards
BPH
1st March 2008 at 11:36 pm #6800
KaptainkwakKeymasterI cant disagree with biquetoast as i havent had that problem.
If you want a new coil i have one here. Its a 3 ohm as opposed to the standard 2.2 ohm that is stock. Will send it for ?30 inc P&P if yer interested mate, thats what it cost me.
2nd March 2008 at 3:59 pm #6807Laudanum
ParticipantI can get new coils for ?25 2.2 ohm, although to be honest I’d buy kap’s as you get a better spark with 3 ohm, just make sure your points and condensors alright.
Another thing to consider on a twin is that the spark goes from earth through the plug then the coil and back out through the other spark plug. So if one sides got a better spark than the other the chances are its either the leads, plug caps or spark plugs.
If the windings were breaking down the spark would be going down on both plugs.
One last thing is to check the polarity of the coil, if the leads are arse about tit the spark is trying to jump against the impedance of the charging circuit.3rd March 2008 at 1:53 am #6805BiqueToast
Participantkaptainkwak wrote:… the standard 2.2 ohm that is stock…..Was that Ohm rating for the later models with electronic ignition?
3rd March 2008 at 8:38 am #6812norman
ParticipantThanks all for the advice.
However just to keer things going would it be better to strip the lot out and put in electronic ignition and if so any reccomendations.
Regards
BPH
3rd March 2008 at 8:41 am #6813norman
ParticipantAnd kaptain I’ll take up your kind offer of thet coil as i have another rather crappy Z750 which one day may roll again.
can you let me have your address and i’ll send funds to you asap.
regards
BPH
3rd March 2008 at 12:48 pm #6801
Good question biquetoast. I got that from my manual and assumed it applied accross the board. I will have a look tonight.
11th March 2008 at 10:53 pm #6802whipkwakaway
Participantone question norman …
what model are you talking about ??12th March 2008 at 7:30 pm #6814norman
ParticipantHello Whip she is a 1978 Z750 B 2 or 3 I suppose.
Regards
bph 😕
12th March 2008 at 8:48 pm #6803whipkwakaway
Participantno problem sir ,
a b2 should have …
the front caliper forward of the fork leg ,
three screws on the front left hand engine cover for the coil field ,
a seperate regulator and rectifier ,
and the engine and chassis numbers between 016101 and 025700 .
hope that helps !! -
