- This topic has 10 replies, 4 voices, and was last updated 5 years, 1 month ago by .
Viewing 11 posts - 1 through 11 (of 11 total)
Home › Forums › All Things 750 Twin › Technical Garage › How To Fix It › Oil filter part number?
Thought I’d do an oil change so got me some oil and a hi flow filter number hf401 which was the number given in the book at my local bike workshop. It’s too short as it’s only 55mm as opposed to the original at 80mm. Does anyone know either the part number or where I can get one. Cheers
I am using HF126
they are 80mm
The Kawasaki part no for the oil filter is 16099-002
There are quite a few after market elements out there available from Wemoto, M&P, Zpower and most other suppliers
just fitted a HF126
Not sure where to get the weird double oseal from though?
Has anyone just put two normal oseal in there instead? What sizes did you buy?
Do you mean the O ring one shaped like a No 8?
Hi KK
Yes , i was thinking of just putting some thin gasket paper behind it the bring it out a bit more or just get two orings
I can supply you with one of these if you are still looking. I have them in stock
Posted
recieved. thanks
Cheers for letting me know Jon
