- This topic has 2 replies, 2 voices, and was last updated 17 years, 7 months ago by .
Home › Forums › All Things 750 Twin › Technical Garage › How To Fix It › removal of centre stand
think theres a split pin at one end but shaft rusts in solid,you could try bending the brackets and waggle the stand out 🙂
Hi ’79 KZ 750 with aftermarket tailpipes, centrestand doesnt go up high enough because of pipes have tried to take ot off. removed clamping nuts and bolts from both sides , taken spring off , trying to knock shaft through top brace of stand , cant see any circlip or pin holding it in.
any tricks ? or just a case of brute force ?
Ta andy
Thanks I will give it another bash
