Home › Forums › All Things 750 Twin › Technical Garage › How To Fix It › Setting up carbs
- This topic has 6 replies, 2 voices, and was last updated 10 years, 10 months ago by
Duffy.
22nd April 2015 at 6:52 pm #5864
Duffy
ParticipantCould any one help in advising me with what the initial set up for the butterfly valves are please.
22nd April 2015 at 6:54 pm #12419Duffy
ParticipantSorry forgot to add for 1979 kz750b
22nd April 2015 at 10:45 pm #12416
MichaelParticipantHi Duffy,
the butterfly valves are set via idle screw and probably needs adjustment via carb synchronisation.
Initial setup is both butterfly valves at same height (synced) and a little bit open.
Do you have the carbs removed from the engine ?
Then you may hold them against a (strong) light and you should clearly see a “slim half moon” at the bottom side of these valves.
Good chance the bike will start, when carb and it’s idle system is clean and fresh fuel is in the tank ๐Cheers, Michael
23rd April 2015 at 7:24 am #12420Duffy
ParticipantThanks Michael, I will post picture showing butterflies before adjustment, balance screw was missing which wasn’t helpful!! Carbs back on, and running better. Now my back wheel bearing gone aaaaah!
23rd April 2015 at 1:02 pm #12417
balance screw / sync screw is definitely needed !
Otherwise the butterfly valves have no chance to work synced.
Without that screw you can’t even set idle speed correctly.
Not to talk about idle mixture screw.
Engine will be running like “shaking a pot of screws!”
As we say: “Lรคuft wie ein Sack Nรผsse!”, which means the same thing ๐How did you solve it, can’t see that on the pics ?
To bad with the rear wheel bearings !
There is a spacer tube in between the two wheel bearings. Don’t press the new bearings to strong against this. With new bearings in final position you should be able to move this spacer tube with a screw driver or even your finger a little bit up and down.
It is bad when this tube is completely loose and you can “rattle” it, but it is worse if it is totally fixed by the bearings.Good luck,
Michael24th April 2015 at 3:46 pm #12421Duffy
ParticipantHi Michael,
Thank you for sharing your knowledge it is appreciated.
You asked how I solved the carbs, well thank goodness for my brother!! He found a replacement screw and has made the adjustments. He has made temporary repairs to split engine breather and inlet from air box to carb. I don’t know how well your English is but it would be described as bodged here. I have garden hose with copper pipe bend from the crank and some two pack black stuff filling any holes in inlet hose!! All can be sorted later but thanks to him she is running.
Trudie
24th April 2015 at 8:42 pm #12418
MichaelParticipantHi Trudie,
for “bodged” I need a dictionary to be honest.
Now I understand ๐Good to know your bike is running again.
That’s what it’s all about ๐Cheers, Michael
