- This topic has 0 replies, 1 voice, and was last updated 3 years, 6 months ago by .
Viewing 1 post (of 1 total)
Home › Forums › All Things 750 Twin › Technical Garage › How To Fix It › Should carb diaphragm spin?
Hopefully someone can answer this please.
I wandered why I could not start the bike and found the right hand carb slider was facing the wrong way by 180 degrees! See pic. I then discovered left hand carb diaphragm tap was pinched and not in its seat. But my question is that the left diaphragm is secure but the right diaphragm can be rotated easily above the slide. So should it be a tight fit or rotate freely? And how do you remove a diaphragm in the first place?
thanks……….
