Home › Forums › All Things 750 Twin › Technical Garage › How To Fix It › Twin without balancer weights ?
- This topic has 11 replies, 3 voices, and was last updated 11 years, 11 months ago by
14th February 2013 at 10:44 pm #8674
KaptainkwakKeymasterNOOOOOOOO 😮 😮
I believe it has been tried and the bike just hops uncontrolably like being on a pogo stick.
I personably would not attempt it because with the pistons going up together something needs to counteract the forces 😛
15th February 2013 at 11:58 am #8679
there are several other twins or large singles out there that have no balancer weights 😉
Yamaha XS650 or SR/XT500, maybe some of the english twins, not sure.Maybe the counterweight at the crankshaft must be modified as well to find the best compromise in reducing the forces in vertical direction (agains piston) and in horizontal direction, where the counterweight at the crankshaft causes forces itself.
May start with some weighing.
The piston (+0.5mm) with rings and bolt is 414 gramms.
Maybe I have to consult a “motor builder” to find out if he can calculate or measure the needed counterweight at the crankshaft.Of course there will be more vibrations, but that is the intention, at least for a hardcore chopper 😉
Attached a graphic that shows the conditions. Especially picture C in the upper line is interesting 🙂
15th February 2013 at 12:23 pm #8675
KaptainkwakKeymasterYour educating me here Michael. I am a Design Engineer by trade but im Nuclear and know very little about engines on this angle. I am interested to see what you find out as it appears you may be onto something but that raises the question ‘Why didn’t Kawasaki do it?’
24th February 2013 at 10:56 pm #8680
Kawasaki wanted to run the Twin as smooth as a 4 cylinder engine and don’t want to make any compromise on that 😉
Let me see what I can find out about that!
I know already a Twin running with a balancer weight positioned “one tooth” away from planned position.
Nothing to feel against that.
Ok, it was an accident, not planned 😉Cheers, Michael
15th April 2013 at 10:04 pm #8676scavpan
ParticipantSounds interesting Michael. I have had dealings with harley twin cranks, but they are on a common crankpin, but are similar in the fact that the pistons rise together, but dont fire together on the same stroke.They have to be statically and dynamically balanced.Scavpan
18th April 2013 at 9:08 pm #5238
for my hardcore chopper project I have to rebuild a motor.
I wonder if someone have ever tried to run the motor without balancer weights?
For sure I will need the chain, shafts and sprockets to drive the oil pump. But the balancer weights can either be removed or reduced to a minimum with a turning maschine.Any experience or comments?
Please let me know 😉Cheers, Michael
18th April 2013 at 9:08 pm #8681
MichaelParticipantHi Scavpan,
there is a “secret” behind all the motor and cylinder layouts.
parallel twins (our twins and the old english ones), twins with 18020th January 2014 at 8:37 pm #8677scavpan
ParticipantHi Michael
Did you ever try the engine without the balance weights?. I have bought an engine where the camchain has snapped and took one of the balance weights with it along with the balance weight drivechain and tensioner mechanism, so I will either run without or try and aquire a set of secondhand balance weights and relative hardware.please let me know how it went
regards
scavpan22nd January 2014 at 12:13 am #8682
MichaelParticipantHi scavpan,
no, I didn’t had the time to start that motor rebuild 🙁
But may have a spare pair of balancer weights and “axles” if you need them …
Make sure that there are no pieces broken off the crankcase, e.g. balancer chain tensioner fixing !
29th January 2014 at 7:23 pm #8678scavpan
Yes, the casings took a battering and have now had them welded just where the tensioner is mounted on the lower case.
The parts I need are
balancing weights with springs and sprockets.
balancer weight shafts.
Balance chain 06bh-sdh.
Tensiner mechanism completeI have the spacers for the balance weights.
I have been trying to find a supplier for the balancing chain, but is very difficult to source, I am dealing with a Japanese company that deal with D.I.D. chain. The number on the chain is 06H (zero, six, H )
Please let me know what you have and how much you require for the parts.
Thanks & Regards
Mark29th January 2014 at 9:14 pm #8683
MichaelParticipantHi Mark,
I should have the weights, sprockets and shafts.
Have to have a look into my spares department 😉Don’t have the chain and the tensioner. These parts crack when the bad moment comes, so no such spares with me.
Will have a look and post pictures when I’ve found them.
They will not have a high price but freight costs needs to be added.Cheers, Michael
1st February 2014 at 5:57 pm #8684
have found the balancer weights 😉
One side is complete incl. washers and bearings,
other side is just the weight(and included components) and the axle, no washers, no bearings.
There are no screws included that fasten/fix the weights to the axles !General condition is good, axles just have some coloured marks, no damage. Can be “polished” and will look like new 🙂
Attached a picture of what I can offer to you. Would that help ?
