- This topic has 4 replies, 3 voices, and was last updated 12 years ago by .
Home › Forums › General › Everything Else › fork length
what in mm is the length of b1 forks from spindle centre to top yoke,i thank you.
also my little chuckle monkeys,measurment from floor to bottom frame rail under engine
Phil Fork length on my B1 is about 30″ = 760-762mm give or take?
Height of frame off the floor I will have to check tomorrow, as my bike is on blocks at the minuet.
cheers matey,trying to work out length of shockers, done away with monoshock back end
Hi Phil,
did some measurements at an original B2, 1977. Only have modified B1s here 🙂
Fork length 755 mm, maybe some additional mm when fork is absolutely full extended.
ground to frame clearance 230 mm
All values are approximate, as measuring conditions where not good.
There are bolt-on kits available for the Kawa Fours (Z900, Z1000) for use with modern swingarm, shock running through large hole in swingarm and upper lug to mount shock is bolt-on to upper rear motor holder. Have you seen that ?
