Home › Forums › All Things 750 Twin › Projects and Progress › Progress Reports › JUST ABOUT FINISHED?
- This topic has 10 replies, 4 voices, and was last updated 10 years, 2 months ago by
AERIAL0.
6th October 2015 at 5:10 pm #5919
AERIAL0
ParticipantBeen a long slog, but nearly finished. Sorry for all the same photos, but just mastering re installing photos with KK’s help.
6th October 2015 at 6:04 pm #12862lonesome
ParticipantLovely job mate, you should be proud 😎
6th October 2015 at 6:37 pm #12866AERIAL0
ParticipantThank you. Could not have got to this stage without the help of the forum. And the help of KK re spares and other members. More photos to follow.
6th October 2015 at 9:19 pm #12860
KaptainkwakKeymasterLooking very nice. Well done you.
Your welcome to the help that is what we are here for. I will also try and help you with the other couple of bits you are wanting.
Hopefully we will meet up sometime???
7th October 2015 at 5:17 pm #12865AERIAL0
ParticipantA brief history. Purchased over a year ago in a very poor state and every thing had been painted with a yard brush.
Had the s/arm, side stand, main stand and battery case powder coated.
Repainted the tank and all panels myself for under £20. Sorted out the brakes. new chain & sprockets and rear shocks. The rest has been elbow grease. Not show condition but clean and tidy.7th October 2015 at 6:05 pm #12863lonesome
ParticipantDon’t suppose there’s a before pic is there? You could morph it into your shiny after version. I’m impressed with the tank – I did mine once and all that boring sanding and spraying was undone by the first coat of lacquer. I’ll get it done professionally some day. Probably the day after the electric start works flawlessly (or at all!).
8th October 2015 at 10:21 pm #12861
KaptainkwakKeymasterVery nice Aerial0 especially that paint job.
How is the exhaust made up?
9th October 2015 at 4:31 pm #12867AERIAL0
ParticipantExhaust is orig down pipes? to a pair of marving cans. The paint work was a pain in the arse to do with all the rubbing down and building up the coats to try and get a good finish. Used Halfords petrol resistant lacquer on the tank.
Only have 1 photo of b4. Please note blow torch in picture. Every nut and bolt had to be heated up and plenty of WD 40 to remove. Just need the mirrors and rev/counter cable to finish and a little more polishing. Then its back to the Z1300.9th October 2015 at 4:40 pm #12868AERIAL0
ParticipantThe Z750’s bigger brother.
9th October 2015 at 9:12 pm #12864Edmund
ParticipantAwesome Z1300
21st October 2015 at 3:46 pm #12869AERIAL0
ParticipantThank you. Spent mega Wonga on the beast from a new exh system which are like hens teeth to get hold of, but in the right place at the right time to purchase plus a new seat unit as well.
Still an on going project as lost spark after having running like a dream. -
