Oil Cooler adaptation
Home Forums All Things 750 Twin Your Lonesome and you Oil Cooler adaptation
Viewing 15 posts - 1 through 15 (of 20 total)
  • #25521
    Doctorot
    Anyone done this?
    #25543
    Kaptainkwak
    That looks very interesting Doctorot. I would like to see the finished article when its done.
    #25593
    chrislwg2
    Hi Doctorot,
    I have fitted an oil cooler. Mine runs off a modified oil pump that is piggy backed  off the oil pump and the oil lines come out of the engine at the front of the sump and upto the cooler.
    #25628
    Doctorot
    Hi Chris. I’m interested in your oil pump setup, are you bypassing the filter? Can you elaborate or show some photos? The last engine I built I had a miss-shift and violent over rev resulting in oil pump cavitation and ended up with rod knock shortly after. I have been considering running a stand-alone electric oil pump to avoid this in the future.
    -Vic
    • This reply was modified 5 years, 8 months ago by Doctorot.
    #25634
    chrislwg2
    chrislwg2
    Hi Vic,
    I used an old oil pump internals to make a pump to run piggy back off the main pump.
    Chris
    #25637
    Doctorot
    interesting, so its a secondary pump system just for the cooler. Very tidy bike as well. I see you have it badged as a 865, what pistons are you running? other engine mods? I’m in the middle of a big bore build myself. Nice work. thanks for sharing.
    -vic
    #25641
    marksav
    Very Interesting work ,nice to see !
    #25645
    chrislwg2
    Hi Vic and marksav,
    The engine is a spare i had so i bored the crnk cases and cyl. block . Fitted new liners and had it bored and honed out to take 84mm pistons.
    When i  got  it running it pinked severly so i fitted a second sprk plug , which cured the pinking.
    #25646
    marksav
    Superb work,how did you know the extra plug would cure the pinking? And what was the compression?
    #25647
    chrislwg2
    Hi marksav,
    In 2006 we met the german 750 twin club at Deulin in Belgium. Martin Schetter had  an 865 he had done and i had a spare engine , so i made it into an 865 , keeping my original engine as it was.  when i had the 865 running there was severe pinking and when i mentioned it to Martin he told me of the second plug. So i fitted a second plug and it cured the pinking. the 865 has been in the bike since 2007 and runs perfectly well on same carbs and ign. timing. My starter motor copes with the extra compression, thankfully,  bescause i’d hate to have to kick start it. Power wise the only thing i’ve noticed is the extra torque. I had the pistons made in germany where Martin had his made, forgot the co. name.
    Chris
    #25648
    marksav
    I see ,Clever those Germans ! And they love old Kawasaki’s.
    #25650
    chrislwg2
    Yes, they were a popular bike in Germany and the U S, not so in the U K,lol. There were 6 of us on 5 bikes, i’m on right , Andy, Kaptainkwak is far left. Lonesome, the 5th bike ,made his own way home
    #25653
    chrislwg2
    There were 20 bikes , out numbered by the Germans
    #25654
    marksav
    Great,do you have plans for a return?
