- This topic has 4 replies, 2 voices, and was last updated 6 years, 6 months ago by .
Home › Forums › All Things 750 Twin › Technical Garage › How To Fix It › Spark plugs
Hi KawaKurt
My apologise for such a late reply but I have been away.
This does look like you are burning to much fuel which could be several reasons, all relating to the carbs.
The first thing I would check is that the choke is working correctly. A choke stuck on could cause this. Secondly I would check the fuel mixtures are correct.
If not a fuelling issue then it is probably oil but that is less likely. In my experience of oil burning the plugs tend to be wetter.
If you need any help with the above please ask.
Which model of twin to are riding? This needs to be known to give more accurate advice.
Thanks for the reply KK. It’s a 77. The choke seems fine. If the fuel mix is wrong, what could be wrong?
A number of things could cause the issue. It could be mixtures not set right, blocked or incorrect jets, incorrect float levels or carb balancing for starters.
Have you removed and cleaned the carbs?
Thanks again for the feedback. I will take out the carbs in the winter. It seems like less of a problem when i drive long tours. Is it difficult to adjust the mixtures?
/Kurt
