Home › Forums › All Things 750 Twin › Projects and Progress › New Projects › Flat Tracker project
- This topic has 26 replies, 6 voices, and was last updated 11 years, 10 months ago by
beachcomber.
26th April 2014 at 11:27 am #10035
dougyt
ParticipantTook the liberty of downloading your pic from Photobucket and inserting it here as the code wouldn’t work. Also deleted the second attempt to post it. Hope that’s OK
Doug
27th April 2014 at 5:14 pm #10031
philpassinghamParticipantgood to meet you today sir,if I was to really need one of those single carb manifolds what would the damage be to my pocket?
27th April 2014 at 8:57 pm #10051
beachcomberParticipantHey Phil,
the pleasure was all mine – thanx for putting yourself out.
I’ll dig out pix etc. Don’t know the final cost yet. I had to get 4 carb sets lazer cut [flanges] to get a half decent price.
I have to get them made up into manifolds – no big deal [ if you can weld ! ] so the additional cost will be whatever the guy charges me for the welding.
I’ll dig out the invoics for the flanges and get the price per set. I’ll just put 10% on for my running around etc.
Thanx again
27th April 2014 at 9:04 pm #10052
beachcomberParticipantHere’s the carb flanges and Weber mock up – if pix pransfer this time !
DougyT – I’m doing exactly what I do on 5-6 other forums – not downloading ? Is it a different system on here ?
Thanx DougT / Michael – now sussed !! See following post.
27th April 2014 at 9:36 pm #10040
MichaelParticipantHow to post pictures from local hard disk ?
Go this way and don’t use the “preview” button supplied close to the “submit” button:27th April 2014 at 9:41 pm #10041
MichaelParticipant… continued:
27th April 2014 at 9:43 pm #10042
MichaelParticipant… and this is the original picture posted as described before and is in the end the result of steps 1 to 4 and is named step 5 in my description:
I typically post reduced pictures. Standard format is 1024 x 768, leads to approx 200 kB per picture.
28th April 2014 at 9:24 am #10053
beachcomberParticipantThanx Michael – I should point out that I AM the original computer dummy !!!
28th April 2014 at 2:46 pm #10043
MichaelParticipantHi Beachcomber,
good to see your pictures 🙂
29th April 2014 at 11:24 am #10033
KaptainkwakKeymasterThats brilliant Michael.
Thank You
29th April 2014 at 11:25 am #10034
KaptainkwakKeymasterVery interesting Beachcomber. I might be interested in investing as well . . .
30th April 2014 at 9:29 pm #10054
beachcomberParticipantThe great thing about Webers / Dellortos / Solex carbs of this style are the ease of tuning and loads of spares at reasonable prices. Also loads of carbs around – £50 – £100. Also they don’t need individually setting up as twin carbs.
There is also a good range of choke sizes around what we need for these bikes of ours. Typically 38mm or 40 mm chokes would be good. As far as I’m concerned that is one more part on the bike which is “future proofed” – knowing I can always get spares, jets, etc. They’re also damn good carbs !
My problem [ one of them ! ] is although I am an auto engineering designer with many auto designs to my credit – I am NOT a welder / machinist. That is to say I can stick two bits of metal together – but it’s not pretty ! I’d rather leave that to the experts.
