Kaptains Log – The story of my B1
Home Forums All Things 750 Twin Projects and Progress New Projects Kaptains Log – The story of my B1
Viewing 15 posts - 1 through 15 (of 31 total)
  • #25805
    Kaptainkwak
    As some of you know during the Covid19 lockdown I decided to utilise my time at home by refurbishing my B1. She is a UK registered B1 that I have owned no less than 4 times. When I have sold her it has always been with 1st refusal if selling on and as a sucker for these bikes I could never refuse. I last bought her back on 29th March 2014 and this time she is going nowhere. She had been sat in my garage for 6 years so not before time I decided to start.
    #25811
    Kaptainkwak
    As you can see she was very tired and in desperate need of some serious TLC. I did attempt a makeover a couple of years ago and although she did run I soon realised she need the full works.
    • This reply was modified 5 years, 7 months ago by Kaptainkwak.
    #25821
    Kaptainkwak
    Let’s go then . . .
    She was so run down both inside and out but I got the engine stripped and out then the frame stripped bare.
    #25830
    Kaptainkwak
    Stuff was sent off for Powder Coating, Zinc plating and the wheels sent away for rebuilding. While waiting for them to return I set about polishing the Aluminium parts
    #25837
    Kaptainkwak
    Then stuff started to come back in.
    Zinc Plating
    Rebuilt wheels
    And the powder Coating
    #25838
    coleighf
    A true labour of love! I know the feeling.
    #25844
    Kaptainkwak
    So the work starts here. We need to refurb
    #25849
    Kaptainkwak
    And now we can start to reassemble
    #25860
    Kaptainkwak
    I sent the barrels and head away to be blasted
    The cut stud in the crankcases was put to one side for now
    and I started the Rolling Chassis build
    #25869
    marksav
    Very nice work ! Good to see a lot being done at home instead of “contracting “ it all out .
    #25882
    Kaptainkwak
    Next I addressed the brakes
    Usual offenders were present
    But finally fully stripped and cleaned down to bare metal
    Then we plant them
    And look what a bit of sun can do
    #25890
    Kaptainkwak
    The wiring harness wanted some attention. A few connectors were replace as well as these repairs
    Resulting in a healthy wiring harness
    #25891
    coleighf
    I was wondering what fertiliser you used in that plant box? When I tried that with Tomorite everything came out red!
    The wiring refurb is interesting. The only time that my B1 stopped on me was in France. A fuse had blown, I replaced and it went again. What had happened was that when I fitted the Oxford cockpit fairing, I had to remove the headlight unit, disconnect it, fit it into the fairing and then re-connect. That meant that the wires were pulled forward a few inches and one of them was rubbing on the edge of the hole that the loom passed through in the back of the headlamp shell. It had chafed through the insulation and shorted out. Some insulation tape fixed it. I hadn’t previously noticed that there was no rubber grommet in this hole as there has been on every British bike that I’ve ever owned. If there had been it would never have happened. It had never occurred to me to look there when I fitted the (excellent) Cockpit fairing, which was similar to that fitted to the BMW R90S.
    #25905
    Kaptainkwak
    That is a trade secret Coleighf . . .
    Cylinderhead and barrels had returned from the blasters so now time to attack the engine starting with the cut stud. I took to 2 engineering firms who both failed to remove the stud. I was looking at spark erosion when my son-in-law offered to do it. He assured me he had the skills and even came to my house with hand tools and demonstrated his expertise. 2 1/2 hours later . . .
    New stud fitted and spare barrels and head were fitted ready for me to try my soda blasting
    #25910
    Kaptainkwak
    It is a messy job with dust and drifts getting everywhere but I certainly does get rid of all the muck and corrosion
