Home › Forums › All Things 750 Twin › Projects and Progress › Kawasaki swinging arm options
- This topic has 13 replies, 3 voices, and was last updated 4 years, 3 months ago by
Andy1198.
17th September 2021 at 10:21 pm #27796
Andy1198ParticipantHi
Does anyone know the width of the swinging arm where it fits in the frame? I’m looking at later model aftermarket swinging arms to fit a wider 17″ wheel & a 150 tyre & want to measure a few up as options
Thanks in advance
Andy
19th September 2021 at 12:02 am #27798
KaptainkwakKeymasterI don’t know the measurements but I can tell you they are different for different models. What model do you have?
19th September 2021 at 8:44 am #27801
Andy1198Participant19th September 2021 at 11:44 pm #27802
KaptainkwakKeymasterLooking at the picture I would say it’s a 1982 Y1 LTD. Check the frame number in the Model ID section of the library.
20th September 2021 at 6:04 pm #27803
philpassinghamParticipanti have fitted a gs500 swinging arm and rear wheel onto a 750b with spacers,another is a gsx750 box alloy swinging arm which also fits and looks the mutts nuts
20th September 2021 at 6:56 pm #27804
Andy1198ParticipantCheers Phil
That is the sort of information i was hoping to get from the group. I’m looking at a 550/750 Zephur swinging arm to fit & need to make a few measurements once I get the bike in my workshop to confirm it will fit in the frame or need minor work to do so.
Andy
21st September 2021 at 6:18 pm #27808
philpassinghamParticipanti do have a zx9 back end thats aprox 260mm at the pivot
27th October 2021 at 5:27 pm #27830
Andy1198Participant27th October 2021 at 5:30 pm #27831
Andy1198Participant27th October 2021 at 5:31 pm #27832
Andy1198Participant27th October 2021 at 5:32 pm #27833
Andy1198Participant27th October 2021 at 5:54 pm #27834
Andy1198ParticipantApologies if I’ve posted loads of the same pictures, been getting some jargon saying the post hasn’t been submitted & when I look, I can see that the pictures are on the forum.
Anyway, went with a Zephyr 750 swinging arm, just needed 6mm off each side of the arm where it fits in the frame, got to make up some top hats so the bush sits on the bolt that goes through the frame.
Trialled a Zephyr 750 wheel to see how a 150 tyre will look, still want to go with supermoto style wheels, next up is a USD front end.
Andy
This reply was modified 4 years, 4 months ago by
Andy1198.
18th November 2021 at 6:16 pm #27847
Andy1198Participant18th November 2021 at 6:16 pm #27829
Andy1198ParticipantWent with a Zephyr 750 swinging arm, fairly straight forward to fit, had to cut 6mm a side off the width of the arm to fit in the frame, need to make some top hats to suit the swinging arm bolt that goes through the frame.
Put the wheel in to see how a 150 rear tyre will look, still want supermoto style wheels. Next up is an USD front end.
