Home › Forums › All Things 750 Twin › Projects and Progress › New Projects › New B Project
- This topic has 36 replies, 7 voices, and was last updated 13 years, 10 months ago by
Tango.
18th June 2011 at 6:44 pm #8100
TangoParticipant18th June 2011 at 6:54 pm #8101
TangoParticipant18th June 2011 at 6:57 pm #8102
TangoParticipant19th June 2011 at 5:36 am #8087dougyt
ParticipantFrom what I’ve seen of Phils bikes this is one of his best completed projects so far 😀
Please keep us updated as you progress with the bike, it looks like you have a bit to be getting on with.
19th June 2011 at 10:15 am #8103
TangoParticipantHa Ha…I believe Mr PP had a reputation for Non standard! 😀
Dose anyone know if you can still get seat locks?
Dougy you’re not wrong I have plenty to be getting on with, Things will go quite slow to start with,as I have to finish a Loft conversion! 🙁 But then I can start sorting out my Workshop & get things moving! 😉 I will most certainly keep you updated with lots of pics.
19th June 2011 at 10:30 am #809619th June 2011 at 4:56 pm #8104
TangoParticipantOhh Nice one m8 Thanks for that, Thats what I need info like that,so if anyone knows of any any handy common interchangeable parts post it up. I wright it all in the back of my manual. 😉
Phil ive found a tank filler cap in a crate and a ignition barrel,Do you know if theres a key anywhere?19th June 2011 at 5:36 pm #8080
philpassinghamParticipantno keys for the ignitions,think most are 6 wire,you need 4 wire,any key will fit the petrol cap,imagine my shock and horror after i spent ages swopping handlebars to find you swopped the #OOPS#s back,kwaks gonna get his legs slapped lol 😀
19th June 2011 at 7:13 pm #8105
TangoParticipantPhil That’s my fault…Did KK txt you? I only realised when I put the two photos up on here! oops Sorry mate,I was mortified when I realized! We tried to ring you, But I said to Kaptin “Im sure he said he wanted the wide bars?” So we decided you had not swapped em over as the others where wider? 😕
Sorry about that! Ill post em straight back to you m8, Let me have your address.20th June 2011 at 11:48 am #8081
philpassinghamParticipantno problem,sorted with kk,doing caveman in 4 weeks,gonna meet with kk and swop them,he will be in touch
20th June 2011 at 3:57 pm #8106
TangoParticipantOk m8 he rang me today! Again So sorry about that! 😳 Did you have any ideas for the rear light as the frame has been cut off,so the light holder isnt there? I could put it back on with a tube inside the frame to hold it,and either weld it or Drill and bolt it so it could come off again. 😀
20th June 2011 at 6:30 pm #8082
philpassinghamParticipantthats in one of the boxes,remembered seeing it,just sleeve it and bolt it on if you weld like me lol
22nd June 2011 at 4:54 pm #8107
TangoParticipantOk its pay day tomorrow, 😆
I said I wasnt going to do this,as ive got a loft to do! But there are some inexpensive bits on ebay that I can add to the new parts already on the old Z.
So I have ordered a 4 pin ignition. a rear brake light switch & ive put a bid on a right hand switch gear.
And ive been given some Bandit bars, (I may yet try fitting these upside down Cafe Racer style? Could be worth a look? And the young lad over the road has taken one of the down pipes that needed a bit of weld on the front flange bit as it was coming away from the pipe.
As he has just got some work experiance at a custom bike build shop;-)
Like I said you have to use what contacts you can eh?22nd June 2011 at 4:58 pm #8108
TangoParticipantOh yer! & a New Speedo cable. 😀
22nd June 2011 at 6:46 pm #8083
philpassinghamParticipantinfectious isnt it lol
