Home › Forums › All Things 750 Twin › Projects and Progress › Progress Reports › Tangos B1.. The Next Step.. :-)
- This topic has 60 replies, 7 voices, and was last updated 9 years, 5 months ago by
19th May 2016 at 3:56 pm #13267
TangoParticipantHard to see… But it’s standing out to me!!
19th May 2016 at 4:04 pm #13268
TangoParticipantI think I’m going to have to live with it!
I have used a Metallic Pearl Paint and if I keep adding more paint to try and get it sorted, I risk changing the colour of the tank,it will start to appear darker! And if I try to rub it down to much to get rid of it! The paint will start to go lighter in patches where it thins to much!… That’s the problem with Pearl Paint!
It’s not bad from a distance, I think I’m just going to have to live with it!
19th May 2016 at 4:07 pm #13269
And it isn’t too bad from the side.
By the time I get the pinstripes on and the Tank Badges in place. I’m hoping that it will look good enough. 😉
19th May 2016 at 7:21 pm #13285
MichaelParticipantIt looks good, mate !
22nd May 2016 at 6:49 pm #13270
TangoParticipantOk… Things are sent to test us..
I had got to the stage of pinstriping the tank… But I tried to use a Petrol Resistant Lacquer. Is isn’t any good! It is so thick it clogged the spray nozzle up not even half way through the tin.. And it is a product that you can not respray over as it will react!!22nd May 2016 at 6:51 pm #13271
This is where I’d got upto…
And a coat and a half of lacquer22nd May 2016 at 7:02 pm #13272
This is where in back down to.
I have had to remove all the pinstriping, and start to sand all the lacquer back off!!
It is a long hard and soul destroying process! 🙁But if I want to get any kind of decent finish on the tank… I’m afraid it has to be done!
22nd May 2016 at 10:19 pm #13238
KaptainkwakKeymasterThat’s a real bummer buddy.
Don’t let it break your heart. You had done an amazing job up to that point. This time you are armed with more knowledge. You will pull it back!
23rd May 2016 at 8:18 am #13292Mikeonabike
Participant🙁
24th May 2016 at 6:53 pm #13273
TangoParticipantWell the problems keep on Rolling.. 🙁
I’ve managed to rub all the old lacquer off…my bloody fingers are killing!!
Part of the problem is that where I have had to rub born near edges, yhe paint has gone back to metal in some places. So I’ve have to put down some primer to give the new paint a key to stick to.Problem is that even though I have rubbed all the lacquer off I’m still getting a reaction when I try and do this!… So I’m afraid there’s nothing
I can do…But Smash it up with a Big Hammer!!!.No only joking.. I’m going to have to sand it back to Flat off any reaction cracks and completely seal the remaining paint with an isolator primer.
27th August 2016 at 7:26 am #13287
beachcomberParticipantI had a similar situation with my tank and seat cowl. Decided to spray a coat of Barcoat isolator before getting down to actual finishing with primer and top coat. Because I’m basically a sad old fart – I stick to what I know – Cellulose.
Anyway the primer reacted with the Barcoat !!! Oooops – that’s not supposed to happen.
I was that gutted after all the prep and work – I couldn’t face hours,/ days of rubbing back and even then not being certain there would not be a future reaction. So – I had the tank media blasted back to bare metal [ £20 ] ! Yes revealed all sorts of dings and dents – but at least I knew I would be starting again without any lurking problems.
The seat was another matter as it was GRP – solution, buy another seat base ! [£35 ]
Good luck.
2nd September 2016 at 3:49 pm #13274
It’s a crying shame, but I have to have a go at trying to save this tank.. So I’ve had to start from scratch. Rubbed it down and Base coated it with an isolator primer! 🙁
2nd September 2016 at 11:20 pm #13289
kayeParticipantOh dear that’s sad i know what it’s like when paint does that 😡
i use 2k and stick with it though some spakle metallic base coat are solvent based and you use 2k thinners with it, and the candy colour lacquer to go over it is a 2k paint but use an activator to make it go off, it can be a mine field if your not sure what goes with what!…..got my new 50 litre compressor for my workshop this week can’t wait to get spraying! good luck huni …3rd September 2016 at 9:52 pm #13239
KaptainkwakKeymasterHang on in there Tango. As Kaye has seen you get out of these babies what you put in. It will be worth it in the end. I’ll be over tomorrow to help take her to the next stage.
4th September 2016 at 6:50 pm #13275
TangoParticipantWell KK came over, we have put some Fine Tuning exercises in on my B1!
First we took the coils off and lifted the rocker cover. We checked the shims
One was out, so it got changed. We also checked the valve timing and found it not quite right… So changes were made until KK was happy. We also checked and fine tuned the ignition timing.
Then we turned our attention to the carbs as mine has a different set on now from what I went to Belgium on, because Maggie stole that set and refused to give them back.
We cleaned and made various changes, with a possible Plug Breaking down diagnosed as well.. The last run of the day felt promising! So a Massive Thank You to KK for yet more of his time!I’m off work tomorrow so I’m hoping to get out and give the bike a good run to see if everything is indeed now working as it should!
Here’s Hoping! 😉
