- This topic has 123 replies, 4 voices, and was last updated 11 years, 11 months ago by
16th February 2014 at 9:16 pm #11133
MichaelParticipantOk, found several pages in the “Kompendium” about this topic.
Let’s start with the coils connected via 3 yellow lines.
Resistance of line to line should be 0,4 to 0,6 Ohms.
Measuring each of these lines against MINUS, result must be infinite.Attached a diagram that shows the rectifier circuit.
Wiring diagrams are available in this forum 🙂Other measurements are by far more complex, need additional temporary wiring.
Please find a guy who has the english language workshop manual.
It is by far to complex to translate and to describe here.
I don’t want to cause severe damage to your electrics by wrong translation ! 😉Cheers, Michael
16th February 2014 at 10:16 pm #11037
KaptainkwakKeymasterCheers guys your help is most appreciated. Michael I fully respect your comments on translation and i will find the correct English information.
Tango has more than one issue here. His starter motor circuit is incomplete at the moment so may deceive diagnosis. The mechanics of the circuit are all in place with the suspected exception of the rollers and springs in the starter clutch itself. That is the main reason he wishes to remove the left hand cover. While the cover is of he will inspect the coils etc for obvious damage. He will also fit the missing rollers while he is in there. The 2nd issue is that the starter solenoid is not operating correctly. He has a new handlebar switch gear so that should be fine. We will check each part of the circuit that feeds the solenoid and if ok we will replace the solenoid.
His potential charging problem is a separate issue. We do not know what the voltage was when the battery was fitted so therefore cannot say the charging circuit has an issue yet. The battery is currently on charge and showing promising results so far reading 12.3 at the moment.
Assuming all is well with the coils we will check each component and the wiring on the charging circuit. The connections will be clean and well insulated so do not worry there.
Once all this has been done we will report back.
Once again thank you for your knowledge and help so far.
16th February 2014 at 10:19 pm #11077
TangoParticipantHi Michael
I am going to remove that cover, Not so much to look for the electrical problem.
Yes I will check I have no trapped or damaged wires while it is off.
But I need to take my starter clutch off to see if I have any of the springs and rollers in it?
My starter just spins the big cog and little cog with the chain on, It does not lock up and turn the engine.I hear what Dougyt said and I need to sort my electric problem 1st before fixing a starter.
But the fact is I need to know if I need to order a starter clutch kit
So I have to strip it down to see what’s needed?And I have a day off work on Wednesday so this is something I can do on my own. With a bit of luck a local supplier may even have a kit in stock.
17th February 2014 at 10:05 am #11134
hi KK,thanks for simultaneous explaination 🙂
Tango, be sure to have a new alternator cover gasket on hand, too 🙂
17th February 2014 at 10:28 am #11135
MichaelParticipantJust had a look at the rectifier circuit diagram again.
All three cables from the “Armature” goes into a 3-way-rectifier bridge.
In the end it should be fine to connect all three cables to it in any order and it should work.
Cheers, Michael17th February 2014 at 4:49 pm #11078
TangoParticipantHi Guys
I think I have a new gasket in my spares Cheers for that Michael But I have some Gasket in a tube if all else fails? 😳
I have got the cover off now!
17th February 2014 at 4:58 pm #11079
TangoParticipantOpps Same photo twice.
The Battery had been on charge over night and it was on the Maintain setting on the Datatool Charger. I have unplugged it while I work on the bike and I will take a reading before I come in tonight.
I am just about to see if I can find a spare B axle to get the starter clutch off! The more jobs I can get done before my day off on Wednesday the more Time I will have to fix what I find?
17th February 2014 at 5:01 pm #11080
TangoParticipantHere’s what Im upto with the starter clutch, as you can see the cogs & chain are there but KK strongly thinks I am missing the springs & Rollers to lock it all up!
17th February 2014 at 5:35 pm #11081
TangoParticipantWell I guess this will be my new Bible for the forseable future! 😳
And look what I got my grubby hands on today to! 🙂
The Service manual says I need a special tool to lock the flywheel? I carnt remember how Andy did it? & it looks different to his! 😕
BONUS! On my Owner’s Manual & Rings though!
The Manual is off a B4 but hey beggars carnt be choosers! and I recon most of the info in there will be roughly the same? 😉17th February 2014 at 6:07 pm #11136
congrats to the manuals 🙂
But especially the part you need with Alternator/Rec/Reg etc. is specific to the B1 and B2 models only !!!
Starter clutch is the same, don’t worry 🙂
I am a fan of solid paper gaskets over “tubed” gaskets only 🙂
I treat the solely use of “tubed” gasket as an emergency repair, not as a mean for standard maintainance.Cheers, Michael
PS: Enjoy your new “bible” ;-)))
17th February 2014 at 6:22 pm #11082
TangoParticipantThanks Michael
I will try and only use a propper gasket But I will keep the tube for emergency fixes only 🙂
I did notice a little scoring on the inside of the flywheel bit? Is this ok or will it have damaged anything?
Oh and thw Battery looks a lot healthier that it did yesterday 🙂
17th February 2014 at 6:22 pm #11137
MichaelParticipantAh, forgot the answer about rotor issues.
Is there any progress in ordering the rotor puller screws?
The rotor holder will be different for a B1/B2 or the B3/B4 and LTD/CSR as the rotor itself is different !
It is extremely important to fix the rotor and it’s LH (left hand) screw firmly and to use medium Loctite on it.
If that screw is not fastened enough, at least the starter clutch again will not work.
Not to think about further “behaviour” and damage that may appear !I prefer to fix that screw with a “pneumatic screwer” [ger: Schlagschrauber], as known from “professional car tire change services”. Sounds a bit like a maschine gun. A rotor holder is not required when this is used 🙂
17th February 2014 at 6:28 pm #11083
TangoParticipantI think you mean what we would call an Air Gun.
Or Air Impact Driver for use with a compressor
Alas I don’t have one of those! But maybe Santa could bring me one for Christmas Next Year!
17th February 2014 at 6:35 pm #11138
that scoring itself is not a big story.
Maybe it had touched the outer metal ring of the inner coil.
It is all very tight in there and within the mechanical production limits at that time (37 years ago!) it might happen.You may check mounting position of inner coil to correct that.
Unscrew just a little bit, move it a bit within its limits and tighten it again may help.Cheers, Michael
17th February 2014 at 6:39 pm #11139
MichaelParticipantThanX,
Air Impact Driver is the word I’ve missed 🙂
M -
