Home › Forums › All Things 750 Twin › Projects and Progress › Progress Reports › I’ve Started
- This topic has 165 replies, 7 voices, and was last updated 11 years, 8 months ago by
Bolton440.
4th May 2014 at 9:15 pm #10576
KaptainkwakKeymasterThanks guys. The downpipes were discoloured before the slashcuts were fitted . You can see that in post 116 of this thread. They haven’t got any worse yet
13th May 2014 at 9:22 pm #10577
KaptainkwakKeymasterAnd now . . . the new rear mudguard
13th May 2014 at 9:32 pm #10578
KaptainkwakKeymasterI am much happier with the longer mudguard. I will however be removing the reflector off the bottom of the number plate and painting the other reflector bracket black.
14th May 2014 at 3:05 pm #10614
TangoParticipantlooking Good mate.
All we have to do now is find a day we are both free to go for a ride and go over finals! 😉
14th May 2014 at 6:13 pm #10644
looking good !
Never saw the longer mudguard painted.
Together with painted front mud guard and the short exhaust it is a different look 🙂Cheers, Michael
16th May 2014 at 9:54 pm #10579
KaptainkwakKeymasterAnother new accessory . . .
17th May 2014 at 9:08 am #10580
KaptainkwakKeymasterHi Michael
Yes the look is completely different. I have tried to give her that retro 70’s style which with mudguards painted I think it has worked.
A few cosmetic changes and technical improvements. I am very happy with how she has turned out.
She is a pleasure to ride and I do get a few looks and nice comments, hopefully the same in Belgium 😀
27th May 2014 at 9:15 pm #10581
KaptainkwakKeymasterSpent another couple of hours tinkering in the garage tonight doing those odd bits. I’m nearly there now apart from a bit of cleaning. Hoping to do a biggish ride with Tango on Saturday. Anyone else fancy joining in?
28th May 2014 at 1:11 am #10645
MichaelParticipantYeah, I want to join that ride 🙂
Just have to finish some electrical work, though 🙂Cheers, Michael
28th May 2014 at 10:13 am #10582
KaptainkwakKeymasterNow that would be good Michael. It is such a shame we live so far apart as I am sure we would get out quite often if we were nearer but you never know . . .
7th June 2014 at 10:10 pm #10583
KaptainkwakKeymasterWell that’s doors shut on bike mods. I had a couple of minor issues to deal with and they are now done. All I want to do know is bleed brakes and clutch then clean her. After that it’s pack and leave 😀 😀 😀
10th June 2014 at 1:30 pm #10584
KaptainkwakKeymasterJust when you thought it was safe to put your tools away . . . ARRRRGGGGG! Went for a test run after reducing the vibrations. Camera works well now. Got home and as I was turning the bike round all the electrics went off. Straightened wheel n back on. Turned to left and off. I’m sure it’s either the ignition switch block connector (had trouble with it before) or where the main harness comes from under the tank n round the headstock. Either way round I could really do without it at this stage. Will be stripping the harness tonite
10th June 2014 at 7:36 pm #10615
TangoParticipantCrack on Sparky
Hope you get it located quickly so you can sort it out mate!
Got all my gear packed today So its just clean the bike tomorrow, & load it Thursday morning!
10th June 2014 at 9:40 pm #10585
KaptainkwakKeymasterBeen in the garage 3 1/2 hours. Eventually found the problem and it is now fixed. It was the 6 pin connector for the ignition switch. 2 of the 4 wires had corroded but were still securely in place. I still have to put her back together but that will wait till tomorrow night. Hopefully I can persuade my boss to let me finish at dinnertime.
11th June 2014 at 6:50 am #10616
TangoParticipantGood Luck with the finish Pal.
At least you found it and managed to sort it out. 🙂
I wonder if your headlight problem was causing some of the buzz on your front? Hope its sorted now you have stiffened it up. 😉
