Home › Forums › All Things 750 Twin › Your Lonesome and you › Marko’s Z 750 S1
- This topic has 206 replies, 9 voices, and was last updated 3 years ago by
Marko.
19th May 2014 at 8:21 am #9585
MichaelParticipantHi Marko,
it is below / under the left hand side of swing arm.
Quite close to swingarm bearing tube.
There must be an “ear” existing.You can see it in the attached picture. Only front part of swing arm shown !
Lower chain guide not mounted.Picture shows the special chain “slider” I have done for the Dirtbike 🙂
19th May 2014 at 8:32 am #9645
MarkoParticipantThank you Michael for all the help!
Other than that, the bike is running fine, as mentioned I was on a meeting this weekend. I will post some pictures when I get them.
Marko19th May 2014 at 12:26 pm #9586
MichaelParticipantYou’re welcome !
19th May 2014 at 10:01 pm #9526
KaptainkwakKeymasterI am pretty sure this is the complete item. If I remember properly the rubber is vulcanised to the steel bracket and not separate items. Kawasaki only list one part number and the number quoted is correct. Good find Marko. I have bought the other one 😀
20th May 2014 at 7:22 am #9646
MarkoParticipantKK, that is good to hear!
But it I have checked the swing arm again, and the brachet that Michael indicated is broken off, so I will have to make a new one.
Marko
20th May 2014 at 7:07 pm #9527
KaptainkwakKeymasterI’ve a swinging arm here that the bracket has departed from it because of rust. They can also get caught and bent so another thing to be careful of.
27th May 2014 at 6:13 pm #9647
MarkoParticipantHi,
I got the part today and it is made only of rubber (no steel support). It is quite hard rubber, but it is flexible.
Because I have to make new bracket on the swing arm, do you think that it should be the same length as this rubber, or maybe the bracket should be shorter to allow some flexibility (maybe half length)?Thanks,
MarkoHere is a picture of the rubber part:
27th May 2014 at 8:50 pm #9528
KaptainkwakKeymasterThe bracket should run down the groove in the rubber and should be folded on both edges to stop it bending. I would suggest 1mm thick material or 1.5mm if you can bend it.
28th May 2014 at 10:02 am #9648
MarkoParticipantThanks KK, I hope that will be an easy job. I am not riding the bike at the moment because of this, so the repair must be done as soon as possible.
I promised some photos from MOTO VET meeting and here are some. I don’t have many of the bikes, we took photos of us mostly. The meeting was at the only motorbike camp in Slovenia, which is owned by a colleague veterinarian. It was a rainy weekend, but it was great anyway! We rode for about 250km that day, all the way to Croatia.
Marko28th May 2014 at 10:16 am #9529
KaptainkwakKeymasterCracking pictures Marko. Looks like you had a great time and George looks happy even though a little shy 😆 thanks for sharing them with us. The bracket should be quite simple to make and fit so you 2 can be reunited again. If you need a sketch I can do one for you
28th May 2014 at 10:30 am #9649
MarkoParticipantA sketch would be helpful, so if it’s not too much trouble for you I would be happy to have it.
Thanks,
Marko28th May 2014 at 11:33 am #9530
KaptainkwakKeymasterI will sort one for you Marko but will have to be this evening when i get home from work.
29th May 2014 at 8:45 am #9650
MarkoParticipantThat’s fine, I will start working on the bracket tomorrow.
Marko
29th May 2014 at 10:07 am #9531
KaptainkwakKeymasterHi Marko
My apologise. I got home quite late last night and didn’t get a chance to get to my garage. I will sort a sketch for you tonite.29th May 2014 at 10:53 am #9651
MarkoParticipantThat’s OK, I really don’t want to trouble you too much. I found a photo of swing arm online, which I think will be very helpful aswell.
