- This topic has 123 replies, 4 voices, and was last updated 11 years, 11 months ago by
1st March 2014 at 2:14 pm #11109
TangoParticipantI then put the Red electrode on each of the 3 pins in turn with the black earthed to the engine case.
I got no change in the reading at all off any of the pins
The reading just stayed at 1.
1st March 2014 at 2:40 pm #11110
TangoParticipantSo Am I correct in saying that With the test from each pin to the engine case. This shows that I have No short from the stator to the case!
But I also think the test on each of the yellow wires shows I have No resistance in the yellow wires! This is Bad isn’t it?
1st March 2014 at 4:10 pm #11111
TangoParticipant??? I haven’t put the foot rests & gear lever back on! As I have a feeling I’m going to be dropping the oil and stripping it all back down again! 🙁
1st March 2014 at 5:10 pm #11064dougyt
ParticipantThat checks out just fine Tango. The coils are all connected together at one end and not to earth, and as they are long single wires in each coil you should have very little resistance between each pin.
1st March 2014 at 6:43 pm #11112
TangoParticipantOK I have found the Manual I have got is a B4 manual, So Not the same as my bike!
But would you say what I HAVE DONE is right?
1st March 2014 at 6:48 pm #11113
TangoParticipantHere is what the manual I have says.
1st March 2014 at 6:52 pm #11114
TangoParticipantThat says I should get 0.32 ohms
I get .001?
Is that not wrong I am confused!
1st March 2014 at 7:18 pm #11115
TangoParticipantI have Just noticed I have Blown my Neutral Bulb again!
This comes from the same connecter block as the Exciter coil? (Is that Correct) is this the round spool of wire that sits inside the flywheel?
1st March 2014 at 7:22 pm #11116
TangoParticipantThe bit in the middle that looks like a doughnut
1st March 2014 at 7:33 pm #11117
TangoParticipantMy head is spinning but If I had a short in this circuit would that explain me constantly blowing neutral bulbs & having charging problems!
1st March 2014 at 7:51 pm #11118
TangoParticipantThe wiring diagram in post #70 (Page 7) shows the wiring running up to the neutral light, the block connector where the two circuits join can be seen more clear in post #53(Page 6)
1st March 2014 at 9:02 pm #11065dougyt
ParticipantIf you’re using the B4 book things will be different from a B2. If your regulator isn’t working correctly you won’t charge correctly and could blow bulbs (as the neutral light is probably the only one on then that would go first).
Your manual says there should be a different reading across the coils from what you’re getting, but as long as it’s similar on all pairs of them and not open circuit and not going to earth anywhere I would take that to be near enough. Your meter won’t be that accurate and the slightest resistance across the connections will change the reading (if you haven’t hit the plug connectors nicely or have some crap on them it will change.)The exciter (field) coil may be causing a fault, check it with your meter again across the two wires. It would be worth checking you get a voltage from the regulator going into the field coil supply wires too.
2nd March 2014 at 11:00 pm #11047
KaptainkwakKeymasterI have run through a few more tests with Tango. I am guessing his Field (Exciter) coil/circuit has a fault. Setting the meter to a 2 ohm range we get a reading of 0.03 on each wire. The book tells me this should be 2.7 to 3.4 ohms so I feel this is where the problem lies.
One other thing. The Brown and White wires that go to the Field Coil are both giving positive voltage readings just under 12V. Does anyone know if this is correct?
3rd March 2014 at 9:43 pm #11066dougyt
ParticipantShould be giving a voltage across the two wires to feed the coil. Again I’d be satisfied with close enough as far as the ohms across a coil, and shouldn’t you be checking between the two, i.e. one probe on one end of the coil, and one on the other.
4th March 2014 at 1:52 am #11048
KaptainkwakKeymasterThat is what I thought Dougyt. Both wires give a reading of just under 12V when measured to the battery negative. We get minimal resistance on the coil (0.03) so I am feeling one of the wires is wrongly connected and may have damaged the field coil.
