Home › Forums › All Things 750 Twin › Your Lonesome and you › Marko’s Z 750 S1
- This topic has 206 replies, 9 voices, and was last updated 3 years, 2 months ago by
Marko.
29th May 2014 at 7:24 pm #9532
KaptainkwakKeymasterHere we go Marko
The guard we have received is slightly different to the original so I have made a slightly different bracket to allow for it.
The first picture is for making the bracket and the second picture is for positioning it. Please ask if there is anything you do not understand.
29th May 2014 at 7:55 pm #9587
you have some great technical drawing skills 🙂
29th May 2014 at 8:13 pm #9652
MarkoParticipantKK,thanks a lot! I agree with Michael, you are really good at technical drawing!
The pictures are clear and I am sure we’ll be able to make the bracket tomorrow – I’ll take some pictures to show the final result!
Marko29th May 2014 at 8:55 pm #9533
KaptainkwakKeymasterThanks for the comments guys. My drawings should be quite clear because as I Design Engineer (currently Nuclear) I do this for a living 😉
18th June 2014 at 12:13 pm #9653
MarkoParticipantWhile you were enyoing at the meeting, I did some more work on the bike.
First of all, the chain guard is installed – thanks to KK’s drawings it was an easy job! As you can see from photos, mirrors have also been replaced, because I could only see my shoulders with originals. I got those from my friend, he thinks they belonged to Moto Guzzi originally. And the brake lines are also new, they are steel braided and braking improved significantly.
Marko18th June 2014 at 12:23 pm #9588
MichaelParticipantHi Marko,
nice bike 🙂
You’re a lucky guy to have the coast line close to you !
Nice area !Have fun !
Preliminary report of 2014th meeting:
http://www.z750twin.de/treffen_2014.htm18th June 2014 at 1:40 pm #9534
KaptainkwakKeymasterHi Marko. I am glad you managed to sort your bracket out.
Michael is right. You are indeed in a beautiful area. Enjoy your riding and keep posting for us to enjoy and envy.
22nd June 2014 at 8:37 pm #9654
MarkoParticipantYou asked for more and here are some photos from today’s ride. This time I went across the mountain pass to Austria. Great road with lots of curves and beautiful views. I felt quite confident on the curves today and the “chicken strips” are gone on the rear tyre, getting closer to the edge on the front.
Marko22nd June 2014 at 9:09 pm #9554
TangoParticipantLooks Fantastic Marko.
Very Nice Scenery!
22nd June 2014 at 10:04 pm #9535
KaptainkwakKeymasterYou have some great roads out there to ride and what better bike could you do it on?
I am a tadge jealous
22nd June 2014 at 10:18 pm #9589
looks great !
Good to see that the recommendation for BT45 is working well for you 🙂
Front tire will always have the “chicken strip” !
Your rear tire looks impressingly good used. That is the limit when tire pressure is ok ! Approx 2.0 bar minimum to 2.5 bar maximum.Going to Austria is the way to my direction.
Did you try it to get prepared to visit our Summer Party incl. a small Z750Twin meeting, happening from Fr. 15th to Su. 17. Aug. 2014 ?
🙂You are invited 🙂
Still close to Munich / Augsburg area.Cheers, Michael
23rd June 2014 at 4:16 am #9655
MarkoParticipantHi guys, you are right, there are some fantastic roads around here, especially in Austria, where the tarmac is much better than in Slovenia. I am plannig to buy an action camera soon, so I can make also some videos of my rides.
@Michael:
Thanks for invitation, I am planning my holidays at the end of July, so I should have no excuse for not coming! It is also a national holiday in Slovenia on 15 Avgust, which makes it even easier.Cheers,
Marko23rd June 2014 at 5:49 am #9590
sounds good !
15th Aug. is a public holiday in Bavaria as well.
Hope to see you soon.
Cheers, Michael29th June 2014 at 2:35 pm #9656
MarkoParticipantI thought I should share the “repair” I had to make today.
I went for a pleasant ride and somewhere in the middle the clutch cable broke! 🙁 Right at the lever, so obviously I couldn’t go on. And than I used a piece of wood and wrap the cable around it – and it worked! I was quite hard to pull, harder than I expected, so I didn’t shift much and I was very thankful that Twin has a lot of torque. I even manged to go safely through 6 traffic lights, but it was one of the longest 80km in my life.Cheers,
Marko29th June 2014 at 6:46 pm #9591
good idea in that bad situation !
Broken clutch cables appear quite often, right at the top end !
As signs of wear appear (single wires broken and spreading (?) is an alarm sign to swap the clutch cable asap.
You can feel the damage and you can even hear a special sound when pulling and releasing such a worn cable.Only good lubrication / greasing and no sharp edges/bends in the upper part of the clutch cable will cure that.
You may replace the LTD clutch cable with a shorter version of the B as you have a lower steering bar.
Should help to avoid the bend in the upper part 🙂A spare clutch cable on board and tools to remove switch lever, left driver footpeg and front sprocket cover or at least the tools to use “screwed nipples” as temporary replacement.
https://www.louis.de/artikel/nippel-bowdenzugsatz-set/10019100?list=4569868
Sounds easy but in fact it is some work to do to use them and a third hand is very helpful !Cheers, Michael
