18th March 2013 at 12:14 pm #8709
KaptainkwakKeymasterIsn’t the bottom one bigger than the top one?
18th March 2013 at 3:44 pm #8772
TangoParticipantI had to go and check then!…No its just camera angle! 👿
Well Ive moved the horn, I have actually looked through my parts and found the original horn and bracket, after Michael told me what it looked like and where it was fitted. Ive fitted the horn I had on in its proper place on the frame now,But there is a snapped stud in one of the holes,so I can’t refit the original horn yet!
The indicators on the front of the bike were the US twin filament bulb type! I wasn’t happy with them,they seamed dimmer? So I have swapped the bulb holders out for standard UK spec ones, and that seams to have made them much better!
Ive also fitted the side panel badges to the panels now,and Ive lacquered in my sticker that I got for inside the rear tail piece. 😉
18th March 2013 at 5:04 pm #8773
TangoParticipant18th March 2013 at 5:06 pm #8774
TangoParticipant18th March 2013 at 8:42 pm #8775
TangoParticipantOps! OK I have found a small set back. While I was doing the headlight, I could not undo the fork bottoms? When I have looked the nuts just spinning? I have got the nuts off the studs now by splitting them! But as you can see on the photo, The threads are gone!
So I need to get some new studs in, What is the best way to get the old ones out of the legs?
18th March 2013 at 8:43 pm #8776
TangoParticipant18th March 2013 at 9:42 pm #8710
KaptainkwakKeymasterWe can get those out mate. I bit of local heat and a pair of stilsons will suffice 😀
Will try and source you new studs too.
As far as the rest of the work is concerned its a big well done from me. I can’t wait to see her finished and go out on the road
18th March 2013 at 9:43 pm #8711
KaptainkwakKeymasterMMMM Are those my crimpers discarded on the floor like a rag doll?
18th March 2013 at 9:51 pm #8777
TangoParticipantNo I liked yours so much! I went and got myself some, Yours are on the worktop! 😎
18th March 2013 at 10:05 pm #8839
I know some tools to remove the studs. Except really large tongs or large pipe wrench there are things like these:
http://www.ebay.de/itm/Stehbolzenausdreher-Stehbolzen-Ausdreher-Bolzenausdreher-6-3-14mm-Universal-BGS-/140936736486?pt=Spezielle_Werkzeuge&hash=item20d07beee6
universal thread sizes, 15,- Eurosor these ones:
http://www.ebay.de/itm/CV-Stahl-Stehbolzen-Ausdreher-8mm-Gewindestift-Linksausdreher-Bolzen-Ausdreher-/261153956813?pt=Kfz_Handwerkzeuge&hash=item3ccdfd23cd
perfect tool, just matching M8 thread, 12,45 Eurosor this one:
http://www.ebay.de/itm/Stehbolzenausdreher-Bolzenausdreher-Schraubenausdreher-Krummerschraube-/200877126510?pt=Spezielle_Werkzeuge&hash=item2ec535b36e
universal, 25,- EurosHave fun,
Michael18th March 2013 at 10:42 pm #8712
KaptainkwakKeymasterI have one very similar to the first you showed Michael. Mine fits a 1/2″ drive socket set. I have not seen the other 2 types before.
Cheers for that
19th March 2013 at 8:12 pm #8778
TangoParticipantYep Thanks guys.
I borrowed a tool just like the 1st one off a friend. And with a bit of local heat before attempting to remove the studs, They came free with a little care! :pint:
I have even ordered the new ones from the local Kawasaki Supplier with new Nuts to match. 😀 Due in on Thursday, So as long as I can get back from work I can have it sorted over the weekend.
19th March 2013 at 8:34 pm #8713
KaptainkwakKeymasterNice one mate. I can pick the studs up friday if you want. I finish earlier than you guaranteed 😀 😀 😀 😎 😆
19th March 2013 at 9:19 pm #8779
TangoParticipantCheers mate, I did cheat a little, I ordered them before I got the old ones out! I did it as I left work! 😕 (Well you said they would come out!)
I think they were about19th March 2013 at 11:20 pm #8840
successful removal of studs is always like a little victory !
Be proud !
Cheers, Michael -
