Home › Forums › New Member Introductions › Hi from Karl
- This topic has 70 replies, 6 voices, and was last updated 3 years, 2 months ago by
Karl.
9th February 2021 at 8:00 pm #27330
Karl
Participant9th February 2021 at 8:54 pm #27379Karl
ParticipantJJ
thanks, I didn’t pay very much for this bike, I put a cheeky bid in on ebay thinking I might be able to use the frame, and won! Its then sat in the back the garage for over 12 months before i had a proper look, I downloaded a manual and i decided to see if the engine was salvageable. If I bought an engine I would still strip it to check it before I would trust it as KK said, there old bikes and the newness will have worn off by now, Ebay is full of bikes or engines that turn over and have compression, its no guarantee of anything.
What the plan with yours
And yes kk I will likely need the shims as you suggested, now the valves and seats have been done, will find out when top end is together.
Cheers Karl
10th February 2021 at 2:52 pm #27384jimmyjaz
ParticipantAfternoon yes you are probably right on the rebuilding of the engine,it will give you peace of mind when it’s all done,and you seem to be flying along.My rebuild is doddle as it just needs finishing off,its 90% done judging by the photos I am still trying to organise transportation to get it up here.I have another one in bits up the road that a mate of mine is storing plus various other engine bits if you can’t source them i.e. barrels,crank ect let me know if you want anything cheers jj
10th February 2021 at 10:11 pm #27386Karl
ParticipantOk thanks
13th February 2021 at 11:29 pm #27390
KaptainkwakKeymasterIt’s always handy to have a pile of bits when restoring one of these twins. Some things do need to be replaced with new parts but there is a great satisfaction when you manage to restore a 40+ year old part so it looks new.
If you are getting rid of any parts please shout up here.
17th February 2021 at 1:36 pm #27403Karl
ParticipantKK
One step forward, two back….
Back in the garage engine biggest part done, come to fit valves and have managed to loose valve spring seats! I remember I couldn’t grip them to get them out, forgot to mention to the vapour blasting lads, possibly still there, if I am lucky. If not have you any? Also went to pick frame up which looked great, apart from around headstock, some contamination from under bearing races, so that’s gone back in to be redone.
Buggeration.
Karl
17th February 2021 at 4:28 pm #27406Karl
Participant18th February 2021 at 7:16 am #27409
KaptainkwakKeymasterIt is coming along nicely now and the fin repair looks really good. I would be pleased with that.
Are you sorted with the spring seats? I can sort some for you if not so shout up mate.
18th February 2021 at 9:41 am #27412Karl
ParticipantMorning KK
Yes if you could sort four spring seats out that would be great, I ordered the shims just in case, i wasn’t banking on vapour blaster finding them.
Also the clutch push rod has been ground away at one end?? If you have a spare can you send one please and a tab washer for the front sprocket if you have any thanks.
Cheers karl
20th February 2021 at 7:56 am #27415
KaptainkwakKeymasterHi Karl
I replied to this the other day but my reply isn’t here? Not sure how that has happened.
Anyway I will sort out the parts you want and let you know mate.
21st February 2021 at 10:41 am #27427Karl
ParticipantThank you 😊
21st February 2021 at 11:35 pm #27432
KaptainkwakKeymasterPM sent
27th February 2021 at 11:39 am #27455Karl
ParticipantParts arrived this morning, thanks
2nd March 2021 at 8:49 am #27459Karl
ParticipantMorning kk
Manual says thinnest shims are 2.2mm, mine are all 2.65mm and tight. Can you supply one 2.2mm shim and I will see what if any gap that gives me?
Karl
3rd March 2021 at 9:28 am #27460
I only have 2 x 2.2 shims so there is a 2.3 on it’s way down to you mate which should be fine to determine the sizes you need.
